Re: Farmall M Carb Needle leak
Posted by Wayne in MN on October 25, 2007 at 13:43:21 from (71.13.41.21):
In Reply to: Farmall M Carb Needle leak posted by Zach Bouchard on October 25, 2007 at 13:27:07:
Which "needle"? The high speed mixture screw on the bottom of the carb or the needle & seat inside the carb??
The high speed mixture screw packing can be tightened and/or replaced.
The needle & seat leakage: 1. replace them if old & worn or 2. shut off the gas tank, remove the drain screw so the carb float bowl will empty, leave the plug out & run some gas thru the carb, shut off the jgas tank, replace the plug & turn on the gas at the tank. This "flushes" minute particles out of the needle seat and allows full closure of the needle.
