Re: Belt pulley gearbox gasket
Posted by CNKS on October 25, 2007 at 19:07:19 from (216.144.104.128):
In Reply to: Belt pulley gearbox gasket posted by Scott Rukke on October 25, 2007 at 16:50:14:
The entire unit has a gasket below it. You have to make it yourself as it is NLA from Case-IH. Any shims are inside the unit.
