Belt pulley gearbox gasket
Posted by Scott Rukke on October 25, 2007 at 16:50:14 from (12.18.181.66):
Does the belt pulley gearbox take a gasket or shims. I was recently told a gasket but an older forum on here states it takes shims and no gasket and that the shims are used to get the proper mesh on the gears.
If it's a gasket where are they available? Part #? Thanks
