Re: Update on Loose 240 U Steering Problem
Posted by Janicholson on October 26, 2007 at 08:46:00 from (199.17.6.122):
In Reply to: Update on Loose 240 U Steering Problem posted by PaulW_NJ on October 25, 2007 at 17:03:43:
Put the arm on the shaft without keys and see if it will tighten up on the taper (very likely because that is what the taper is for) then take a thicker Woodruf key and grind it down to fit the augered out hole in the shaft. Do the same for the tapered key way in the arm. Do the same for the other side and keyway. This will take a bit of dremel action, but very doable. The arm should tighten up on the taper with just a little more of the bolt sticking out, If the washer would now push on the sholder of the shaft, put a larger ID washer to allow the nut to drive the arm tight on the shaft's taper. When it is just about to be put together the last time, put Locktight brand stud and bearing mount liquid on the surfaces of the taper keys and shaft. Tighten it, then use a big socket, and a hammer over the nut driving the arm onto the shaft farther, then tighten , then drive the arm on more then final tighten and pin the nut.
The taper tightness is 50 % of the holding force of the system. It wuill work, for little money. JimN
