Re: Farmall H Loader
Posted by Janicholson on October 27, 2007 at 16:44:20 from (66.173.50.38):
In Reply to: Farmall H Loader posted by Martin Miller on October 27, 2007 at 15:29:39:
It should bolt on.
The hydro on the 300 might be 3 to 400 PSI stronger, so if the cylinders were smaller in diameter, it will be a little less on break out lift.
A two way valve can be used (many pics and discussion in the Search For box above). The existing rod will be need to be wired/held back all the time to allow the pump to run. It will not have live Hydro, (the hydraulic will stop when the clutch is in). JimN
