Re: Hydraulics on Farmall H not working
Posted by GeneMO on October 28, 2007 at 03:29:03 from (216.74.196.145):
In Reply to: Hydraulics on Farmall H not working posted by hbauer on October 27, 2007 at 19:33:02:
The pump does come out the bottom. There are several methods for doing this. Two people and a floor jack really helps. Once out you could replace that pesky leaking seal.
Wonder if that heavy grease you put in by mistake is plugging or bridging over the oil intake area of the pump and not letting it get oil?
You might try flushing it with diesel fuel or kerosene for a little bit, then draining that out. I think most folks say to put 30w non detergent in them. If it was working before you put the grease in it, then that is all I can think of.
Good luck, Gene
