Posted by hbauer on October 27, 2007 at 19:33:02 from (12.76.194.230):
All of a sudden my hydraulics do not work on my Farmall H. Out of the blue. I did put the wrong fluid in at one point 90W, but most of it ran out the bottom anyway, which is another problem..dripping from the case. I put 30 W in...still not working. I'm not too good with hydraulics obviously. Could the problem be with the hose or dirt on the fitting. Some guy told me you can pull the pump and filter out easily and check it. Is that what I should do and does it come out the bottom? HELP. I can't lift my cutter up....the tractor's that is. Mine still works! :}
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
