Re: Hydraulics on Farmall H not working
Posted by Janicholson on October 28, 2007 at 08:13:45 from (66.173.50.34):
In Reply to: Hydraulics on Farmall H not working posted by hbauer on October 27, 2007 at 19:33:02:
Look at the parts diagram --caseih.com-- follow the instructions to search for parts. The pump needs to be taken out to service it. One item not mentioned is if the lever has loosened on the shaft, it might cause the problem. THe most likely is a pressure relief valve stuck open (a piece of dirt) these pumps would not be damaged by 90 wt, but in cold weather they might have operational reluctance. Some use ready rod (allthread or threaded rod) to lower the pump after all the elbows and the lever are removed. JimN
