Re: 350 Hi Utility Next Problem
Posted by CNKS on October 28, 2007 at 09:11:40 from (216.144.104.128):
In Reply to: 350 Hi Utility Next Problem posted by Pat in Wisconsin on October 28, 2007 at 07:09:20:
If you work alone, invest in an engine hoist. For safety (those hoists can tip over), remove the rims from the centers. Then the wheels can be removed safely and relatively easily. I believe you can remove the cap and pull or carefully dig the seal out. Just don't score the place where it fits. On the tractors I have done, I also replaced the gasket between the axle housing and the rear end--may not be necessary in your case, but I have never tried to remove one with the axle in place. Gaskets/seals don't come in a set. They can be purchased from your Case-IH dealer, the seals are likely cheaper from a place that specializes in bearings and seals, but the cap seals aren't expensive, anyway.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
