Posted by jjohnson on October 28, 2007 at 15:18:02 from (74.192.70.222):
In Reply to: Re: IH 464 Running Hot posted by the tractor vet on October 25, 2007 at 08:20:30:
Well...this test was interesting. When I cranked the engine without the belt on and with the cooling system filled to just above the water outlet with the radiator hose turned up, a big slug of coolant came out even before the engine started. The engine has never been hydraulically locked, nor have I seen coolant in the oil, so this is strange. One would expect a direct passage into the combustion chamber to see this. Anyway, after the initial slug, some bubbling was evident until the block heated up and started to push coolant out. Upon removing the head, I didn't see any evidence on a bad leak. It has the metallic head gasket, and I've had trouble with these on large, two-cycle industrial engines. The middle two cylinders are burning whitish, while the outer are black. There is a small area between one of the chambers and the water jacket that could be a crack, but I'm not sure. I guess it's off to the machine shop.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
