Re: H starting issue(s)
Posted by old on October 28, 2007 at 17:50:55 from (4.244.218.102):
In Reply to: H starting issue(s) posted by CJAA on October 28, 2007 at 17:47:00:
First off is it 6 or 12 volts?? You may have a bad battery cable or 2 which would cause that. Or yes you could have a bad ring gear. Pull the starter and then slowly turn the engine over and look at the ring gear to see if maybe you have some bad teeth on it
