H starting issue(s)
Posted by CJAA on October 28, 2007 at 17:47:00 from (216.41.207.229):
Had the H running, shut it off and about an hour later it wouldn"t crank. I have since had the starter checked, new battery, new push button starter, wire wheeled all the battery connections. It will now crank a couple of times and then nothing, I can hear the starter getting enough juice to make it click. I"ve heard that maybe the ring gear is bad, how do I know? Also, if I turn the fan blade by hand, I can see the ring gear moving,(with the starter out of course. I have long arms too) but, I get to a point where I can"t turn it all. I have rocked it back and forth in reverse, 5th gear and still nothing, I have not tried to pull start yet. Thanks for any advice/comments!
