Re: H starting issue(s)
Posted by Janicholson on October 28, 2007 at 19:26:50 from (66.173.50.157):
In Reply to: H starting issue(s) posted by CJAA on October 28, 2007 at 17:47:00:
If the starter is dragging inside it will spin like new with no load. I would check starter current by using a cheap gauge that is held to the side of the bat cable, or check the volts at the battery (for three seconds) while the starter is engauged. Should have 85 to 90% of no load volts or starter is dragging/shorted. JimN
