Re: H starting issue(s)
Posted by old on October 28, 2007 at 19:54:15 from (4.245.3.152):
In Reply to: Re: H starting issue(s) posted by CJAA on October 28, 2007 at 19:39:17:
Ignition swithc has nothing to do with it turning over or not. The engine should turn over with it on or off because they are different circuits in the system. Most of the time you have to make your own cables or maybe go to a tractor dealer to get them becuase most auto parts stores don't carry the bigger cables but some can order them in. Also a good place to use as a ground hook up is one of the starter bolts since then you have to ground right at the starter, which I do on most of my tractors if I can
