Re: H starting issue(s)
Posted by CJAA on October 28, 2007 at 19:39:17 from (216.41.207.229):
In Reply to: H starting issue(s) posted by CJAA on October 28, 2007 at 17:47:00:
The ground (positive wire off battery) is grounded to the frame. I still can't get over the mental hump of this positve ground thing! I had the starter tested and the guy said it should be okay, he had it whirling pretty good, but it was out of the tractor, which could be proving the bad battery cable idea. Can the cables be bought specific to the tractor or do they have to be made? Could the run/off switch have any factor in this or does that only figure in once the tractor has started? I have no reason to believe its bad but just eliminating possibilities.
