Re: H starting issue(s)
Posted by J in Pa on October 29, 2007 at 14:01:27 from (24.239.59.159):
In Reply to: H starting issue(s) posted by CJAA on October 28, 2007 at 17:47:00:
if you have checked everything cables, grounding ,etc. get the starter checked again.lots of times a weak starter will show good on the bench test.
i had a problem with mine for about ren years until a fella told me about some lugs that have wires soldered into them inside the starter, i think for the brushes. these wires will get hot and short out causing the solder to get hot and flow out of the connection.
result, sounds like a dead battery even with a new battery in it.
mine looked good on the bench test but under load its a different story.
good luck
J in Pa
