Re: Farmall 300 350
Posted by D Slater on October 29, 2007 at 19:12:59 from (71.182.17.176):
In Reply to: Farmall 300 350 posted by DougSr on October 29, 2007 at 18:33:57:
If tractor hasn't had parts changed around a 300 will have the key switch in dash or gage panel. 350 key switch is down below panel on left side with a push button in gage panel to send power to starter solinoid. Rear light was mounted on right side of battery box 300, left side 350. On side of engine block above oil filter and tappet side cover should be in raised cast C 169 for 300. C175 for 350. Look at clutch pedal below piviot point at botom. 300 will have a bolt with lock nut to limit lever travel. 350 clutch pedal end won't be drilled for the bolt. There's some more different, but that should tell you.
