If you have the extra IH "christmas tree" valve that aloows for 2 way operation, you can use it or the liftall, strickly singel action, but not both at the same time. Whichever is not used is blocked. I needed 2 valves on my SMTA so I ran the pressure line from the live pump to the inlet of the valve setup, the return from the valve setup goes to the inlet of the liftall reservoir(where the pressure hose goes now) the return from the reservoir goes back to the pump. You could conceivably use the liftall for a separate single acting cylinder also. I don't think the belly pump is an option on the SMTA as the housing is filled with TA.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
