Posted by bc on October 30, 2007 at 15:22:04 from (69.148.26.227):
Hi, I have the loader/backhoe that corresponds to the Ind 606/2606 which may also be similar to the 460/504.
I recently replaced the top seal in the power steering hand pump because it was blowing a lot of oil out the top around the steering wheel. The hydraulics on the front loader and the backhoe seem to work ok. However the steering seems to want to stall out with a load in the front bucket. Even without a load, the steering is still sluggish and slow and balks when I try to turn the wheel as hard as I can. It also makes the usual hydraulic hissing noise like it is bypassing or something. I have to backup and go forward again a few times to make basic turns sometimes as well as keep the motor revved up. When I put the bucket down and raise the front wheels off the ground, they turn back and forth just perfect.
I recently replaced the fluid and filter. I also remember reading some posts about the bypass valve and some kind of relief valve under the seat but I can"t find those posts after searching for them.
Is there a way to trouble shoot this such as loosing lines to check for flow, etc? If it might be the bypass valve (I"m not sure I can identify it) or this relief valve under the seat, how do I R & R them? Thanks for your help again.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
