Re: Ind 606/2606 460/504 hydraulic steering hard to turn
Posted by bc on November 04, 2007 at 19:15:51 from (69.151.187.126):
In Reply to: Ind 606/2606 460/504 hydraulic steering hard to turn posted by bc on October 30, 2007 at 15:22:04:
Today I pulled the adjusting screw and spring from the control/pilot valve. The ball stayed inside but I could move it with wire. I also pulled the plug assembly and ball. Turned the motor over some to pump some fluid through the holes. Put them back in, started it up and still have the same trouble of hard steering. If it is the check valve in the control valve, then I will probably have to take it all loose and R & R it on the bench. I was just hoping there might be something plugging something somewhere but nothing is readily apparent.
I couldn't get the power steering lockout loose from the flow divider valve.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
