Re: H starting issue(s)
Posted by CJAA on October 30, 2007 at 18:30:36 from (216.41.207.229):
In Reply to: H starting issue(s) posted by CJAA on October 28, 2007 at 17:47:00:
Update 2:Had the plugs out again tonight, engine will spin all the way around using the starter, it will NOT spin around when I try to do it by hand. Any ideas??
