Re: Swapping rear tires on a BN
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by gene on February 21, 2000 at 03:49:16 from (63.25.167.123):
In Reply to: Swapping rear tires on a BN posted by Dave BN on February 20, 2000 at 14:55:52:
the correct size are 8.3x24 the rims were 7 or 8 or 10 the standard rims usually were 8 in if the rim measures 9in overall the rim is a 8 inch if it measures 8in it is a 7 inch the rims can be moved by moving the 4 bolts inside or outside of the four tabs on the rims have 11 B AND BN be glad to answer any and all questions
Post A Followup
: Re: Re: Swapping rear tires on a BN
