Re: horse power rating
Posted by Red Dave on October 31, 2007 at 16:32:04 from (68.44.136.10):
In Reply to: Re: horse power rating posted by smigelski on October 31, 2007 at 16:10:31:
The 100 Chassis serial number prefix is "100"
The 130 Chassis serial number prefix is "130"
The serial number should be on a plate on the left side of the clutch housing.
At the practical level, there isn't much difference between the two models.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
