Re: MW to a IH Pump
Posted by D Slater on October 31, 2007 at 21:49:30 from (72.65.158.38):
In Reply to: MW to a IH Pump posted by Rich Griffin on October 31, 2007 at 19:16:23:
If your tractor is a 1950 there's a engine serial # break on the front cover and plate to the correct bolt pattern for the IH pump. If its older the bolt pattern is different. If newer the same bolt pattern as IH pump. On some M front covers though the pump shafts with snout for a hour meter drive gear will contact inside of cover just before a flush bolt up. This is just a guess on engine serial # break without looking it up, but I seem to remember it may be 228050.
