Re: h hyd drive seal
Posted by Bob Kerr on October 31, 2007 at 21:57:21 from (64.12.116.73):
In Reply to: Re: h hyd drive seal posted by Bob Kerr on October 31, 2007 at 21:53:58:
I did forget to mention, that pump is heavy! use a floor jack and some blocks to lower it and it helps to have some extra hands in case it wants to fall off the jack as it clears the belly. There is just 4 bolts holding it in and you have to take all the elbows off and the filler cap also.
