Re: h hyd drive seal
Posted by Bob Kerr on October 31, 2007 at 21:53:58 from (64.12.116.73):
In Reply to: h hyd drive seal posted by Gary Spitznogle on October 31, 2007 at 16:51:15:
First drain the rear end, then drop the pump. The round part with the slot for the pump drive shaft is a nut. it comes out like a normal nut. I used a 1/4 square screw driver shaft and some cussing to get mine out. Then the 3 bolts that hold the housing come off and so will the housing. The bearing will come out too. the seal drives out from the inside of the housing. If I forgot something someone will chime in.
