Re: h hyd drive seal
Posted by Nebraska Kirk on November 01, 2007 at 05:03:13 from (207.91.30.92):
In Reply to: Re: h hyd drive seal posted by Bob Kerr on October 31, 2007 at 21:53:58:
On an H you don"t have to remove the belly pump to change the lower tranny shaft seal. There is enough room between the shaft and pump to get your hands in there and take stuff loose.
