Re: S M Head number
Posted by Buck E on November 01, 2007 at 09:27:48 from (205.188.116.73):
In Reply to: S M Head number posted by Buck E on October 31, 2007 at 20:06:48:
D. The tractor serial #is F2094J. Engine serial # is 2185K.All cast numbers on tractor are in march 1952, so this was early SM. By the way . I drilled a hole in back of valve cover and with fitting and hose, hooked to Air cleaner connection, also put 1/4 in. pipe in front where oil was draining to gov. It works like supposed to an no oily smell. Thanks for your help. Buck E
