Re: C123 sleeves
Posted by El Toro on November 01, 2007 at 11:54:24 from (205.188.116.73):
In Reply to: C123 sleeves posted by Doug C. on November 01, 2007 at 11:08:31:
You can bump them out from the bottom with a piece of 2X2 oak and a hammer and just tap on them. They're not pressed into the block.
If you don't have engine off the tractor I don't think you get the crankshaft out. Your flywheel and clutch are all connected to name a few items.
Hal
