Re: C123 sleeves
Posted by El Toro on November 01, 2007 at 12:52:51 from (205.188.116.73):
In Reply to: Re: C123 sleeves posted by Doug C. on November 01, 2007 at 12:32:11:
You need to measure that crankshaft for being eggshaped or worn. I would pull the engine and then you can examine the clutch fo wear. That block area needs to cleaned where your sleeve seals are and at the top of the block where the recessed area is for the top of the sleeves. Hal
