Re: International Harvester 140
Posted by Hugh MacKay on November 01, 2007 at 15:45:42 from (209.226.247.95):
In Reply to: Re: International Harvester 140 posted by mud remover on November 01, 2007 at 05:36:27:
According to that serial number, your tractor was the 13th one built in 1975. It apparently has the wrong decals. The name "McCormick" does not appear on any International tractors after 1967. Plated metal decals were not used on 140s after 1963.
What your tractor should have are adhesive decals, with the word "INTERNATIONAL" each side on the hood. Then down on lower portion of sheet metal over radiator a model badge, wider at top than bottom, with the word "FARMALL" in inch high latters and below that "140" , in 2" high numbers. The above are all adhesive.
On the grill near top, in red and black is white metal IH emblem with I in the middle of the H.
