Pat, it could be a 21 as Scotty said or a 24. They look almost identical. I have one of each and the only difference I can see is the 21 has one spring on the back and the 24 has two. They called this a heavy duty mower. If you email me, I can send pics of both. I have mowed many acres over the years with mine. Like said it is a fairly straight forward mounting. You need the axle clamps and it bolts right up. It can mount in the right hand axle notches or left. They are very good mowers. They do rattle and shake a bit, but that is normal for most pitman mowers. They ride very close to the ground which will stick you when crossing ditches and such. When in good shape that mower and a good C/SC will mow with anyones outfit. Better than most.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
