Posted by El Toro on November 02, 2007 at 04:07:35 from (205.188.116.73):
In Reply to: Stuck '49 Farmall H posted by Harold From Idaho on November 02, 2007 at 02:46:00:
I would have the head reworked at your local auto machine shop and have it magnafluxed for cracks. If the engine is stuck I would pour ATF into the cylinders and let it soak. You should loosen the main and rod caps. You may need to use a piece of 2X2 oak and a hammer to drive out the pistons. If the sleeves are pitted you may need to split the tractor and redo the engine. The crankshaft may need machining too. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
