Re: Problem found with 130
Posted by scotty on November 02, 2007 at 10:29:23 from (199.231.49.128):
In Reply to: Re: Problem found with 130 posted by EZ on November 01, 2007 at 20:07:01:
Hi Ed,
Those darn pot metal gears just seem to fall apart over time. I would lean towards what Hugh said, and even if you want pull the cover off the transmission and claen everything out good with kero, put new gear oil in and try it out. I would think all the smaller pieces would come out the drain hole. The bigger pieces will stay put on the bottom of the case ! Good to hear you an !
scotty
