Re: Super A with anti freeze in oil pan
Posted by Red Dave on November 02, 2007 at 10:44:43 from (66.216.141.163):
In Reply to: Super A with anti freeze in oil pan posted by Red State on November 02, 2007 at 10:31:20:
Some possibilities, in no particular order:
Bad Head Gasket
Leaking O-Ring seal at the bottom of one or more sleeves
Crack in the head
Crack in the block
If I was you, I'd hope for a head gasket. It's fairly easy and cheap to replace them.
