Re: Belt pulley for my H
Posted by RustyFarmall on November 02, 2007 at 23:02:12 from (66.43.253.19):
In Reply to: Belt pulley for my H posted by Scott Rukke on November 02, 2007 at 17:34:49:
Yes. the 39s and very early 40s were different. Not only does the engagement lever point in the opposite direction, but more than likely the gears inside are narrower and not as strong. I don't know for sure, but it is also possible the gears will not mesh correctly with the gears in the tractor. You'd be better off to find the correct assembly. Someone who is restoring a '39 might be needing the one you have.
