Re: Hydraulics on Farmall H not working
Posted by hbauer on November 03, 2007 at 11:48:39 from (12.76.194.195):
In Reply to: Hydraulics on Farmall H not working posted by hbauer on October 27, 2007 at 19:33:02:
THANK YOU ALL FOR VERY INTELLIGENT AND COMPREHENSIVE REPLIES. I KNEW I COULD COUNT ON YOUR GUYS.
WHEN I HAVE MUCHO TIME, I WILL TRY ALL, STARTING WITH THE KERSOSENE DRAIN AND REFILL AS THE EASIEST.
YES, THE HYDRAULICS WERE WORKING PRIOR TO PUTTING 90w IN IT, BUT SAT BEFORE I TRIED TO USE IT AGAIN.
I will check mechanicals, as I do not think it is the pump....just my hunch. Will let you know when problem is solved or fixed. Thanks again. hbauer
