Posted by Doug N on November 03, 2007 at 12:21:20 from (205.188.116.73):
In Reply to: F-12 govener posted by oldiron29 on November 03, 2007 at 04:27:28:
Old Iron, The main shaft will have some play, but yes the bearing is replaceable. If you look in the block where you took out the governor you'll see a brass bushing just above the cam where the shaft goes into. Once it's in that bushing there should be no play. The bearing is 2.046" OD and .982" ID. Part number is IHC ST-208. You'll need to press it apart. I have mine apart now for bearings.
Now as far as the other piece having play. You shouldn't have hardly any at all. I have no play at all on mine. when it is on the shaft it is snug, but not so snug that it doesn't move. That piece is brass, and it goes between the weights and the thrust washer to the fork. Some play won't hurt, but alot could cause binding and be stuck wide open. If is too terribly sloppy and can't get one thru Case IH, A machine shop can easily make one out of brass. It's a very simple piece. Just make sure you take them the gov shaft so they get the ID of the bushing right.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
