Re: McCormick W6 Voltage Regulator
Posted by John T on November 04, 2007 at 07:14:02 from (66.244.83.147):
In Reply to: McCormick W6 Voltage Regulator posted by Allan Lance on November 04, 2007 at 06:51:45:
Sorry no part numbers here, but if you have to purchase a more generic substitute Voltage Regulator just get one for a Class A Charging System (what most tractors except for a few Fords are),,,,,,,,,,,,,,, for the correct (6 or 12) voltage, of course,,,,,,,,,,,,,,,,, and suitable for what your ground is (+ or -),,,,,,,,,,,and then some are 3 terminal (BAT ARM FLD) while others are 4 Terminal (BAT ARM FLD LOAD) BUTTTTTTT either one can still be made to work so dont let that be a worry. NOTE this assuems its a full fledged Voltage Regulator as you claim instead of a simple 2 wire Cutout Relay, but if it is that should be even easier to replace with a generic one. THE PROBLEM IS some young punk pimpled teenage kid at a parts house wont have any clue what your talking about as far as the specs above so hopefullyyyyyyyyy some IHC knowledgeable gents can give you an exact IHC or Delco etc part number and what it is you have, VR or relay.....
best wishes
John T
