Re: Farmall Dry Sleeve Puller
Posted by TMonton on November 04, 2007 at 07:40:38 from (71.67.147.248):
In Reply to: Re: Farmall Dry Sleeve Puller posted by Red Dave on November 04, 2007 at 07:31:22:
I have heard the same thing.
Using a wire feed welder, run a bead down the inside of the sleeve. Theory makes me believe it would expand from heat and be even tighter.
But on the flip side, the bead will soften or melt the metal enough to collapse and remove tension. This was a tip from an ole' farmall guy up north.
I am a little weary of doing this against my welding skills. I made this far without breaking or ruining anything. I would just feel better using the right tools.
