Re: H Pilot bearing
Posted by Steven f/AZ on November 04, 2007 at 12:39:50 from (24.121.167.138):
In Reply to: H Pilot bearing posted by Flameffects on November 04, 2007 at 09:56:52:
You cannot remove the flywheel without splitting the tractor...
You CAN change the clutch and pressure plate without splitting the tractor. Of course you will have to remove the belly pump and drive shaft for it, and you will also need to remove the driveshaft from the clutch to the transmission.
YES, the pilot bearing can be removed and re-installed without removing the flywheel. Any decent auto parts store should have a pilot bearing/bushing puller.
