Re: Farmall Dry Sleeve Puller
Posted by Fancy Farm on November 04, 2007 at 15:35:22 from (204.10.131.52):
In Reply to: Farmall Dry Sleeve Puller posted by TMonton on November 04, 2007 at 06:33:28:
I worked off and on for a year trying to get the dry sleeves out of a 354 perkins. I destroyed 2 1 inch sleeve puller rods on one sleeve. I finally got the welder out and ran a bead up both sides of the sleeve and that sleeve pulled right out not by hand but it did pull with no problem.
I used a 6013 on 90 amps and pretty is not a requirement. All you are doing is using the heat to shrink the sleeve a tiny amount. Don't try to weld a pretty bead just get it hot and be happy.
I installed the puller in the sleeve with the puck tightented up to keep the slag out of the lower end of the engine.
