Re: 460 diesel trans main shaft
Posted by polinidad on November 04, 2007 at 16:42:09 from (66.153.66.235):
In Reply to: Re: 460 diesel trans main shaft posted by TominKy on November 04, 2007 at 06:38:32:
tractor is split at front of trans, top shaft is out, 4th gear has broken teeth, not enough space for rear shaft bearing to clear case and lift out. Can't move shaft back to clear front. Took idlers out, tried to drive bearing back off shaft after removing snap ring, but won't move. Going to take pto shaft out, remove bearing retainer and see if this will work. Thanks for all your help...
