Re: no spark at the point and no lights
Posted by El Toro on November 04, 2007 at 17:29:56 from (64.12.116.73):
In Reply to: no spark at the point and no lights posted by bob t on November 04, 2007 at 17:20:25:
Your battery may be dead. You need to check for battery voltage at your ignition switch. Your switch may be fed voltage from the starter solenoid. You need to use a test lite or volt meter and trace your wires back to where the voltage is supplied. If its fed from the small
terminal on the starter solenoid check there first
and then at the switch. Could have a broken wire. Hal
