Re: no spark at the point and no lights
Posted by glennster on November 04, 2007 at 17:30:46 from (68.60.242.156):
In Reply to: no spark at the point and no lights posted by bob t on November 04, 2007 at 17:20:25:
if you have no power at the coil and no lights, either dead battery or bad connection/broken wire somewhere. get a test light, clip one end to tractor chassis so you have a good ground, then start at the battery and check each connection. test lite should lite up at each connection, when it doesnt, you found the problem. start by cleaning up the battery termnals for corrosion.
