Today I pulled the adjusting screw and spring from the control/pilot valve. The ball stayed inside but I could move it with wire. I also pulled the plug assembly and ball. Turned the motor over some to pump some fluid through the holes. Put them back in, started it up and still have the same trouble of hard steering. If it is the check valve in the control valve, then I will probably have to take it all loose and R & R it on the bench. I was just hoping there might be something plugging something somewhere but nothing is readily apparent.
I couldn't get the power steering lockout loose from the flow divider valve.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
