Re: Super M Hydraulic Pumps
Posted by glennster on November 06, 2007 at 11:52:47 from (76.224.26.7):
In Reply to: Super M Hydraulic Pumps posted by City-Boy McCoy on November 06, 2007 at 11:44:47:
good to see you're back. yup you can take the hold down bolt off the distributor and pull it straight out and then reset it back to one. there aiint much room with that double pump set up. you almost have to remove the oil filter to work on the distributor. you could eliminate that pump by using a priority vale off the live pump if ya want.
