Re: H oil pump piston removal
Posted by glennster on November 06, 2007 at 11:56:18 from (76.224.26.7):
In Reply to: H oil pump piston removal posted by 49h on November 06, 2007 at 11:42:28:
spray some pb blaster on the oil pump housing where it goes in the block, then grab the pump and twist it side to side a little to get it to move. once its loose, it should slide right out. to get the little metal retainers loose from the rod bolts, catch the edge of em with a small chisel and tap it in a little to bend them out a little, then put a socket on the nut and tap down,.it will spread the retainers open and flatten em for ya!!
