Re: Super M Hydraulic Pumps
Posted by Bob M on November 06, 2007 at 12:28:16 from (151.190.254.108):
In Reply to: Super M Hydraulic Pumps posted by City-Boy McCoy on November 06, 2007 at 11:44:47:
third party image
Mike - The distributor with a PS pump tucked between it and the live pump makes for a tight squeeze indeed!!
If you remove the wires, then the cap and rotor you may be able to wiggle the distibutor out.
The task however is MUCH simpler if you remove the oil filter can and element first!
