Posted by Janicholson on November 06, 2007 at 17:34:51 from (66.173.50.169):
In Reply to: I-6 posted by 460anger on November 05, 2007 at 15:34:22:
A late reply, but here goes: Use a pipe tap on the hole in the hub so that a plug can be screwed in. Put a grease zerk in the plug, and pump grease into the space between the axle and the hub. 10 to 15,000 psi pushing on that surface area should push it off pronto. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
